DKneble
- 123
- Mar 13, 2006
Phoenix,
Arizona
I realize this is a topic that has been
over and over again and there are over a thousand threads dealing with it but I am actually finding it a little difficult to search through them all to find a case that sounds exactly like mine which has a resolution posted. I've read 30 or so threads after skimming a couple hundred and I believe I have pieced this all together properly but was hoping for some confirmation of sorts.
After doing some overhaul work(replacing gaskets) the car (6 bolt btw) was running great for a week or so with no oil leaks. Then after some romping on it on I95 and holding 20psi or so for close to ten minutes straight (hauling butt to catch a train) and coming home I noticed the oil on the garage floor. Probably a couple tablespoons of it after sitting overnite.
Took a look underneath and there was a good amount of oil sprayed everywhere so I'm guessing this happened during that stint of high boost and high rpm. The source seems to be around the oil filter housing or above it a little but very hard to tell. However, there is no oil on the timing belt. Also, my oil pressure guage stays within the norm for the stock guage but I realize I need to get a "readable" one asap to check it.
What I have concluded is that chances are the oil pump is not leaking since there is no oil on the belt or cover. I'm guessing that its either coming from the filter housing-motor gasket, the filter-filter housing, or the pressure sending unit. The oil is pretty much all on the drivers side and I just redid the oil pan seal so I was hoping thats not it but it probably wouldnt hurt to do it again.
Is this a pretty reasonable conclusion or should I still be worrying about the pump? Or front cover? (which is my worst nightmare)
Thanks
Dave
over and over again and there are over a thousand threads dealing with it but I am actually finding it a little difficult to search through them all to find a case that sounds exactly like mine which has a resolution posted. I've read 30 or so threads after skimming a couple hundred and I believe I have pieced this all together properly but was hoping for some confirmation of sorts.After doing some overhaul work(replacing gaskets) the car (6 bolt btw) was running great for a week or so with no oil leaks. Then after some romping on it on I95 and holding 20psi or so for close to ten minutes straight (hauling butt to catch a train) and coming home I noticed the oil on the garage floor. Probably a couple tablespoons of it after sitting overnite.
Thanks
Dave
