Passmossis
- Dec 7, 2007
Temperanceville,
Virginia
I am having an electrical issue in my 1998 eclipse gsx. The problem I'm having is, it seems like something is draining my battery or my alternator is not charging the battery. I've had my battery tested, it checks out good. Give the battery a full charge (2a overnight), the car turns over (little sluggish) but starts. Can run the car for 3+ hours idle, no issue. Aftermarket sterio on/off, works fine. Cut the car off, go to turn it back on and it won't attempt to roll over.
Things I've done.
Checked battery for bad cell
Given battery a good trickle charge
Removed stereo cap/amps from electrical circuit
Kindof leaves me questioning the alternator. Everything electronic works fine when the car is running (except note, read below). I do hear the engine's idle pan up/down by turning on/off eletrical devises at idle; not by a lot but can be heard. Turning steering wheel/headlings/AC, ect. That's been normal since I've owned the car.
*Note, with my cap/amps turned off I noticed my stereo head unit would toggle on/off really quickly when I go from idle to 1st.
Reading through other posts of a similar but different nature, should I have my altinator checked? Or check the fuse for the altinator?
I appricate any help given.
Eric
Things I've done.
Eric
