SPD CAT
- 30
- Dec 18, 2005
macedonia,
Ohio
over the summer i replaced the slave cylinder thinking it was the reason that the clutch engagement was so close to the floor, i replaced the line going to the slave cylinder and still had the same problem still. i remember that when i got the slave cylinder there was a little spring in there with a little plate on the end of it, will i see any difference if i remove that spring and plate setup for more of a free flowing set up. and just to make sure, that little plate goes at the beginning of the threads instead of the bottom right? i have a brand new master cylinder that i want to install but after readinf all the horror stories with the headache trying to set it at the right engagement spot kinda made me want to wait on doing it. If the cap on the master cylinder isnt sealed properly will that affect the operation of the clutch pressure? i always wondered that cause it doesn't lock into place or anything it just pushes on to the reservoir. sorry for all the questions, i just see myself replacing the entire setup including clutch, throw out bearing and flywheel just trying to fix this issue. i haven't ownded this car for a whole year yet and i already feel like that i am ASE certified hahahaha, every dsm owner should get a free ASE certification with ownership of a DSM this is crazy!!!!
(the cars create their own adjectives/verbiage in their owners vocabulary...like "rassafrickin' piece of"...)
Just my opinion, I could be wrong.
