koho2731
- 70
- 1
- Feb 28, 2005
Dover AFB,
Delaware
Well as its says my base timming is sitting at 24* at idle. I found this problem the hard way when I wasn't logging and when into boost any started detonating bad at 5K. So I figured boost lk no big deal, but no lk. So I started the car up and started logging timming is reading 24* insted of the 6* it normally reads. Here is my question my engine coolant temp sensor is bad. Which I'm pretty sure it just controls the fans and shouldn't screw with timming. So I'm pretty much just looking at the ECU, CAS, and the crank position sensor right? Btw all the timming marks are all good.
