moparmadd
- 40
- 2
- Feb 27, 2005
Mason,
Ohio
Ok so about 3 or 4 weeks ago I just got done rebuilding my 1991 Talon TSI AWD. The bottom end now has eagle H-beams and 9:1 wiseco pistons. The block was decked but only to clean a few scratces off. The head was also milled all 3 sides but again, just enough to clean any imperfections. I upgraded the injectors to Precision Turbo 550's. Of course the exhaust manifold was cracked so I upgraded tp a UPC Tubular manifold. Replaced the O2 sensor since it was getting .9 of a volt and the wiring was somewhat melted from before. Also installed polyeurethane motor mounts. Right now the new motor has 1000+ miles on it
Now for the problem... Under high RPM boosting or cruising above 75 mphthe engine will kick the the MIL and have a "31 : knock sensor" code. It goes away if you let off the gas and slow down. If i cruise at 70, it won't kick the code. I dont have a manual for a 91 so Im not sure if thats just saying its a bad knock sensor or its tripping the sensor. The EGR is still installed as I was afraid with the higher compression might raise the combustion chamber temp too much. I heard something about "phantom knock"? I have no clue what it was about, I merely heard it in passing and thought it might relate... THANKS FOR THE HELP!!!
