Seraphix
- Mar 25, 2004
fort wayne,
Indiana
So my dsm has become more of a lifelong problem then a mode of transportation...
From a general diagnostics point of view, my car is stock. Free mods done include hacked air can, removed silencer, cosmetic- relocated battery to rear (0 gauge stinger 12.9v off, 14v engine on) current is not a problem.
I have an idle problem. a week ago it used to run fine until it hit normal temp, the fan kicks on and it drops from 800rpm sputters and backfires and hangs around 500.. dies occasionally at stops. I have tried 4 different ISC, new CAS, Replaced the injectors with known good from a buddy, tried multiple ecu's.
yesterday i popped the throttle, replaced the shaft seals, and the FIAV as i noticed coolant residue inside the intake side of the throttle, thought this would resolve my problem, to no avail, it still lobes. I leak tested a week back and found the shaft seals leaking. I have yet to retest, however everything is sealed with silicon, new gaskets, etc (i'm getting very good at making leak free connections)
Somewhere in the middle of this i developed a gnarley misfire. I found a loose connector on the #4 injector wire , resoldered a new injector connector (thx slowboyracing) Still missfires.
Found a bad plug wire on another cylinder (makes me wonder how it was running-the connector had jammed up inside the wireplug and wasn't even making contact with the plug) . Replaced that. Still misfires. Now i have great spark at all 4 plugs, new injectors and still am misfiring like crazy, almost like i'm missing a cylinder. I've examined all plugs, none fouled, none blackened, none whitened.
I have 12+v at all injector wires with key to on. All injectors test 3ohms.
The car will idle somewhat, Put it in gear, and it's pretty apparent i'm missing a cylinder. Around 3-4000rpm the tach goes crazy and starts jumping around. Ran fine a week ago, with the exception of the idle lobing problem.
I'm aware the lobing problem is probably just a silly air leak i have yet to find, but the sudden misfiring is keeping me from getting to that. Next plan of action is to test the harness and grab a noid light, then it's back to plugging the turbo pipe and testing for leaks again.
Just curious if anyone else has as any insight, or personal experience. Am i going about this completely wrong?
I have yet to add any mods until i can get stock to run right. Car is in pristine condition, no body rust, 19in lcd custom fiberglass in dash(not installed yet, no wiring done). =P
Tell me i'm going about this the right way, throw out some ideas, i've read hundreds of threads on idle problems, leaks, BISS resetting, ISC check/test, TPS adjustment, etc, i feel like i've tried em all.
Frustrated and tired....
imho.
