Ecu Problem
brygsx95
56
Aug 26, 2005
pooughkeepsie, New York
Well today i went to start the car, and well it just did'nt want to stay running so i decided to pop the ecu out, and there are def pieces missing from the board... almost seems like they were melted. Now im just not sure where i can get a reliable ecu??? I wish i could have some luck with this car. oh and im not even sure what ecu to get... i have a 90 awd talon someone please help
Here is a nice chart that will list the part numbers for a 90 ECU. Remember that a 91-94 ECU will work with some slight modifications.
http://simon.chi.il.us/ECU/ECUID.html
If you can take some pics of the bad part of the ECU you might want to send them to this guy. He is also a member on here, very helpful too.
One more thing, when you refer to your ECU as having melted areas are you refering to the capacitors leaking? If so, it is a common problem that can normally be fixed. Not sure if you know what I am refering to but the capacitors are the cylinders in the first pic of the second link that I posted.
yeah they do look like they are leaking.... so what should i do have it sent out and fixed?
