iowntheskies
- Feb 6, 2006
Melbourne,
Florida
So after class today I went out to my car, a 96 2.0L Non-Turbo 2WD Auto trans Eclipse, to head home for the day and turned the key to hear a short buzz or whine and then silence. All the normal lights on the dash turned on as did the radio (which turned off at start position). After about 4 more silent attempts to start I called it quits thinking that the battery just didn't have enough juice to turn the starter. I returned later in the day with my roomate and his car to try to jumpstart it, and after even more failure to start he came up with the idea to check the fuses. The "starter fuse" was in perfect condition, but we did find that the "motor fuse" was burned out. The fuse was replaced and after another silent failed attempt to start the new motor fuse was burned out. I'm thinking that there's either a short in one of the starter wires, my starter is busted, or my engine has seized and the starter can't turn so it burns out. I'm really praying that its not the last one, because I love my car and would hate to see it go. I'm thinking the seize is unlikely as I hadn't driven the car for more than 20 minutes at normal city speeds, and there was no indication of a warmer than usual engine such as high temp gauge or oil pressure light. Any thoughts on things I can try to trace down the problem before I go out and buy a new starter? Any help is appreciated.
