toxic18b
- Feb 13, 2006
Columbia,
South Carolina
Ok I have tryed alot of stuff but can not figure out what is going on with my car.
1st My car often has somewhat of a Idle Surge when hot it will idle between 1000 and 2000, But that is on a rare ocassion. Also to add one day I heard in the back of my Intake Manifold a loud Air leak but I do not hear it anymore.
2nd at 1st my clutch was slipping so i replaced it the flywheel was fine it only had some heat exposure no cracks etc.. But sometimes when i give the car some gas the turbo kicks in the car goes but often it will not go and it sounds like the flywheel is just free spinning. I took the tranny back off and everything is fine.
I also replaced the Slave Cylinder and am in the process of replaceing the master. I adjusted the clutch it is a little stiffer now but I hardly have to engage the pedal for the clutch to engage.
Someone please let me know what might be the cause of these things. Im running out of ideas.
