How much boost?
I see that you have 550's. With those injectors and the translator to add fuel with a datalogger start to raise the pressure. You should be fine at 18PSI. There is the possibility that you will be able to run more, but without a datalogger I would not suggest it. Anymore, may be more than the sidemount can handle. Every elevation and car is different. Log and Raise.:D
