semirb86
- 37
- Sep 28, 2005
erie,
Pennsylvania
i have a 97 gs and when i start the car up, it wants to die. I have to keep reving it so it can stay on. Once i get going its fine but as soon as i get to a stop sign or light. Same problem starts, it wants to die in the first gear,
i have to sit there in neutral keeping my car alive. Please help me.
When was the last time you had gotten a tune up. Same thing happened to me in me in my 1g. I had to change the idle and I had to change out the fuel filter as well as the pump. worked for me. Get back to me.
Thats very good you had change out the Water pump because that might be one of the major problems. If it was the battery you might need a new alternater, on top of that if it was battery, you would stall in an idle. If your battery dies alot means its no good and wont keep a very good charge. Change that one you have for an Interstate, Diehard or optima. battery wont jump the timing. Again you might have to change out the fuel filter.
