Cel P1102
Awsniper
41
Aug 28, 2005
Honolulu, Hawaii
97 GST Spyder
I did a search on the code and came up with 1 post, that was not finished.On Stock MAS This code keeps popping up, and I have no clue what it is. Car does idle good, but with the code on, it stalls out when reved. In idle my logger was giving me ignition of 8, Fpr was at 44 (stock rail,stock injectors). code is P1102 Unknown Powertrain DCT, Manufacturing control fuel and air metering.
Safc is set to 0 across the board. Maft not installed (have not set it up yet).
Car smeels alittle rich, but no smoke. Air/fuel guage is never in the stoich area at idle, bounces from full rich to full lean. need help car has been being work on for 1 yr. and this is the final problem.
like in that post, did you do a boost leak test? do you have someone that you can swap out your MAS with and see if it works then?
Compression test: 175 in all 4, I did a boost leak test and found 1 small leak on the hose that connects to the Bov, but no other leaks. no one here that i now of with the Mas. Im just gona connect to MAFT up and see what happens then.
Ok i installed the maft, The same code is still comming up (P1102). the maft still needs to be tuned a bit. It wont boost over about 2-3 psi. seems like the car starts to stall out or something. unsure if its fuel cut, or something else. If any one can help or has any suggestions. I am still working on tuning the WOT on the Maft. Any help would be good. Thanks
