6 bolt swap, doesnt start
Fayt
515
15
Mar 26, 2005
Cleveland, Ohio
Alright.. just got my 6bolt put in after 4 months, and now it wont start. It cranks over, but thats it. Wont start, wont spark... nothing. Yes, there is fuel in the gas tank before someone says that :p Any idea on why it wont start at all?
I had the motor prepped by Buschur (shop couldnt get the parts from the 7bolt to fit onto the 6) and they replaced a lot of parts on the motor... they removed the balance shaft, replaced the water pump, and redid the timing belt. Dunno if that would have to do with anything, just throwing that out there... any ideas are welcomed.
Well, I found out the coil pack was bad. I'll check tomorrow to see if the CAS is bad too LOL :sosad:
I dunno if I can handle much more good news :| :| :notgood:
Edit : For some reason, its not showing up AFTER this last guys post...
Have you checked the cam angle sensor? When I pulled out my 6 bolt for a rebuild, my cas sat on a shelf for a half a year. When I put it all back together I had no spark or fuel, turned out to be a bad cas.
