Ohhh Noooo !!! : (
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
i was tightening my head in increments on 20lbs 40lbs 60lbs 80lbs ft lbs when tightening down my head.
before i was on 20 ft lbs i lubed up the threads on my ARP head studs and lubed up the washers with 30 weight motor oil ..and after getting to 40 ft lbs i noticed oil on the block. :cry:
since the head wasnt tightened down enough the oil leaked from the head onto the head gasket then onto the block...and at that point i didn't want to take the head off because i would of had to get a new head gasket and i just got this COMETIC that cost me $100..
so will i be fine or will i blow this head gasket ? :confused: :cry:
need help asap !!!!! :dsm:
It will be fine. The oil will not compromise the sealing of the gasket. Just torque it to spec and then retorque after a couple of heat cycles.
wow your always on top of my posts and your always helpful !!! :thumb: thanks alot for the good info 92awddsm !!! :cool:
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
