9!'clipseDOHC
Moderator
- 4,913
- 484
- Aug 24, 2003
El Paso,
Texas
My freshly rebuilt 1991 4G63T engine shudders hard under boost. At about 3K rpms with about 8lbs of boost it starts shuddering, sputtering, and refuses to accelerate. At first I thought it was the fuel pump because I still had the non-turbo fuel pump but I just installed a Walbro 255lph and a Buschur/SX AFPR set at 38psi with the vacuum line off and it is still doing the same thing. I don't know what else to check. Also the "check engine light" is on saying something like "Fuel pump or control relay". It said that with the non-turbo pump and still with the walbro/SX setup. When I let off of the accelerator so that there is no boost or just like 3lbs it runs fine but its a piece of crap with boost. I was better off, faster, and had a lot more money with the non-turbo. I don't understand.
