baf32
- 30
- 2
- Jun 28, 2005
NY,
New York
I finally thought I had my car running well, but it looks like as soon as you fix one thing something else breaks.
According to my pocketlogger (MMCD), the front o2 sensor stays at a constant 2.03v! The voltage remains the same if the oxygen sensor is plugged or unplugged. Regardless, there is no CEL stating the 02 is bad. Bad sensor or more of a wiring problem?
The timing belt is getting chewed up on the inside edge closest to the engine. In addition the belt no longer sits centered on the cam gears, but is pushed out towards the outer edge of the gears. It seems like there is some play when I push/pull the crank pulley. What could cause this to be happening? Either something is wrong with the crank pulley, timing belt pulley, or BS belt pulley or I have crankwalk...
Any ideas would be much appreciated.
