my_gst95
- 569
- 10
- Nov 13, 2002
Sacramento,
California
Refrencing my 92awd. I looped this line because I modified my 92 to have a oil cooler and a oil-cooled turbo so these lines are no longer needed. When I was driving to work, the line I had on there broke. I went to autozone real quick and put a sturdier line there just to get me to work. So I need to make sure before I drive home today that it is ok to run the lines in this matter. My concern is, did the original break due to old wear? OR did it break because both of those outlets are "Coolant Output" lines, causing a pressure-buildup point? I just don't want it to bust on the way home or til I get a chance to weld those two nipples flat.
Thanks,
my_gst95
