Got a Diagnostics??????
dsm_basher
Apr 7, 2005
CDA, Idaho
So I have a 1993 eagle talon that started studdering under boost and would idle fine. Then the check engine light would come on. Now it is worse and studders under no boost. Here is what came up.
1. o2 circuit sensor problem
2. #19-TPS out of range
3. #28-No cylinder 1 Top Dead Center sensor signal
4. #29-Vehicle Speed sensor circuit
Also said at the bottom- Found Broken wire to camshaft position sensor. Wiring Problems to TPS.
Would any of these cause the car to act like this. And do any of these things matter all that much. I know the camshaft, tps, and tdc are pretty big. Let me know what I can do.
Stuttering under boost is either a boost leak or bad/wrong spark plugs.
Do a boost leak test.
Repitition promotes understanding.
Then, replace your O2 sensor and TPS. After you've replace those, put her back together and reconnect the battery. You did disconnect the battery when working with electronic didn't you? Drive it around for two minutes then check for a CEL. Post back your results.
