GZ-Rahvin
- Mar 2, 2004
tampa,
Florida
where is the most common place for the hks to leak...i found mine to be leaking very very badly between the large O-Ring and the Large Black valve under the casing. Wut happens is when i shift and the throttle is closed the large valve will close slightly off center around the O-Ring making you leak when you shift and boost again..anyone else find this happening to their HKS unit
