Satchmo
- May 13, 2005
Rolla,
Missouri
I have a 90 Talon TSI and it is constantly smoking white smoke out the tailpipe after startup, and when you try to give it some gas, a gigantic cloud of white smoke comes pouring out the tailpipe. It smell like coolant, so I thought it was a BHG, but the compression is 140-145 on all cylinders using a dry compression test. After the car is running a while it also starts to smoke around the exhaust manifold toward the o2 housing and downpipe and I see some fresh oil around that area too. The car was quite low on coolant, so I filled it back up, but now my coolant is overflowing like a madman. I think it could possibly be the turbo, but how do I check if the turbo is leaking and where from? Is there anything else that could cause this problem that I haven't thought of yet?
Thanks a lot,
Joe
Thanks a lot,
Joe
