Oh Joy! A new leak!
khrispy
47
Mar 18, 2005
San Diego, California
Now in addition to a power steering leak, I have a huge tranny leak (this is from the transmission, right?) I'm guessing the only way to fix this is to have the tranny pulled and have the gasket replaced, right? $$$$$ :cry:
actually it looks like the drain bolt is loose or leaking, or the axle seal is bad. Either way you will not have to remove the trans, maybe the axle at the worst.
Ya, Its either the axle seal or the tranny plug. I have an axle seal that is leaking and its right on the same spot just not as bad. I replaced both even though one of them wasnt leaking, and what happens? The one that wasnt even leaking has started to. You wont have to pull the tranny for that though. It really helps if you have a lift though haha. Good luck.
