92Talon251
- 220
- Sep 26, 2003
Fayetteville,
North Carolina
1.) First Question I am removing my head to replace a head gasket I have every thing off all the belts and all, I have removed the pullies except the crank pully. I took loose the 4 bolts but the pully wont budge is that square peg in the middle a bolt as well? does it need to be removed, I have tryed just everything but hitting it.
2.) Second Question When replacing the HG I read somwhere you need to trim a mount or something so the head sits level on the block. Is this true? if so what do I need to trim?
Thanks
Thanks
