Turbo Girl
- Sep 24, 2004
Olathe,
Kansas
After doing a lot of searching on this forum, I came to the conclusion that my clutch pedal assembly needed to be welded. After I let off the clutch, I could reach down and pull the pedal up another inch or so. The cluch wouldn't disengage until I turned the adjustment rod until it was holding on by only a couple of threads.
So I pulled out the assembly (which was a pita, by the way) and it was perfect. There was no wear at all. I got it welded just in case and I still have the same problem.
The car is a 92 AWD w/ a new ACT 2100.
What else could my problem be? I know I could fix it with an extended adjustment rod, but I'd rather really fix the problem.
Thanks.
Thanks.
