TSiWarrior
- 300
- 10
- Feb 17, 2005
Detroit,
Michigan
Im on vacation at my fathers here in new orleans LA. I drove the car from detroit michigan and she barley made it. I need to be able to make it back home and I cant even get the car 10 miles without something breaking... Here are the problems some advice or ideas would greatly help.
1. Temp light goes to 1/2 and stays, even during 20 hours continous driving... even when steam is pouring out from under the filler cap.
2. Overheats but no light turns on, boils over from resivor
3. Oil ALL OVER the driver side wheel area, around the altrantator area but I cant find the source of the leak.
4. Small steam leak from behind engine area cant really find source.
5. Tranny makes weird noises, almost sounds like a bad p/s pump
6. Wont shift half the time, it will go into nuteral and you have to forcefully shift the gears, can take up to 3 min to find reverse.
7. Gas mileage is about 18-20mpg
8. Makes a bad u-joint sound during accel and bumps the car, but I checked all the joints and ball joints they are semi-worn but nothing to worry about right now.
9. This one is weird, and I mean weird... When turning left on an incline the car shows symptoms of horribly bad fuel cut. All lights, gauges etc all stay on, but the car acts like someone was cutting the igniton.
That's alot of problems, but any help would be nice.
What about a fuel pump? Working
