chowda633
- 169
- 3
- Dec 31, 2003
Newport,
Rhode Island
When I go WOT for a constant amount of time the boost gauge reads almost 20 PSI! It goes to about 19 then falls back down. Even though I did not let off the throttle.
I had a friend with me to confirm this. Am I leaking somwhere?
Also when it hits almost 19 PSI when it peaks the engine seems to hicup once or studder just one time and then the boost pressure contunes back on the down swing at a rapid rate. Im still using the stock turbo.
It would also do this same thing even when not going WOT just cruzing. I had some knock here and there but seems to be phantom.
Running 93 Octane
Plugs Gapped at .50
Royal Purple oil (Napa now carries it)
And how is that homade boost tester on DSMTuners.
Running 93 Octane
Plugs Gapped at .50
Almost went through the rail ha. Glad im riding about 2 inchs off the ground
