Boost leak
JDR7919
301
Jan 1, 2005
Titusville, Florida
So the problem Im have is my car with not go over 5k rpms in 1st or 2nd when Im getting on it, and sounds like my Msd 2 is staging.
So I was thinking it might be a boost leak, I did a boost leak test and my EGR gasket was leaking really bad; I have it blocked off. I replaced the gasket and its still leaking. Could this be causing the problem? Would any of you have any other ideas?
I have also checked the plugs and they looked fine; I have them set a .028.
Should I use a silicone sealer with the gasket?
Please help............
Has anyone else had a problem like this?
The EGR was blocked off but leaking, so I replaced the gasket. It does not seem to be leaking any more. I still cant go above 5k rpms; I think I may have a leak in the TB. Could a leak cause this problem?
Thanks for the help.
Oh yeah a leak at the TB could defiently cause that. Do you have a datalogger by anychance?
Possible Timing off?
