clutch problems
urbanracer04
Feb 12, 2003
Mays Landing, New Jersey
I got a Clutchmasters 2500 series clutch installed last June along with a Fidanza flywheel. I should've also gotten my slave/master cyclinder done at the same time, but of course I didn't. My master cyclinder started leaking around a month after my clutch install (the clutch pedal kept sticking more and more over time) and finally went in the beginning of January. I got both cyclinders replaced, but just recently my clutch has started slipping. I haven't beat on my car at all since the summertime so asked my mechanic and he said that the bad cyclinder most likely put un-needed pressure on the clutch and that's why it's slipping already. Well my question is, am i going to have to replace the whole clutch or just the pressure plate? i mean it just started slipping like last week, and also i was wondering is my flywheel gonna be fine?
I was just thinking maybe it is adjusted incorrectly giving you pump up, but if it feels the same all the time I guess not.
