Possible electric/battery problem?
dantsi
87
Feb 28, 2004
N/A, South Dakota
I went to go move my car into the garage, as I'm starting it up, I hear this squirly type noise when the ignition begins -- and then I see my car go from 1200 rpm, to 2000 rpm and then sink back down slowly...
So I turn the car off, my power locks don't work, my CD player reset itself and spewed my CD out, and I turned off my headlights -- but my headlights were still on! WTF!
So finally after a third try, everything was all right -- but it sounds like it may have something to do with the battery.
Make sure that your battery terminals are tight and check the three fuses/relays that are attached to the + terminal on the battery. Do you have a factory or aftermarket alarm? Make sure that it also is functioning properly or is hooked up right.
mike :dsm:
I found out what it was, wires connected to my battery (forget which sign) became loose and slipped out... grr... luckily I had a buddy help me out with that. :thumb:
