rowlex
- 1,298
- 28
- Apr 12, 2003
Everett,
Washington
Hey guys...I just got a said "new in box" apexi avcr. I've hooked it up and soldered the connections. I dont know why and I will check it tommorow but now my HKS TT type-1 is not working.
Here is my problem: Installed the AVCR, soldered connections, DID NOT hook up the solenoid valve that attaches to the wastegate and boost source. I DID hook up the pressure sensor. When I get in the car and put it into ACC the buttons light up, the display does not. when I turn the car on the display still does not light up. Anyone have any suggestions? Can anyone with an AVCR verify that the display wont light up unless the solenoid valve is hooked up, and to a vacuum source? I tried to just hook the solenoid valve up (not connecting the vacuum tubes tho) and there was no change. The display still did not light up. Thanks for any help in advance!!!
