tylerk
- 152
- 1
- Sep 28, 2003
Cambridge,
Massachusetts
Ok, here's the problem as it stands right now. I've had what I believed was "normal" DSM belt squeal for a while now. The other night, I had to pull off the road and give up because my alternator and water pump stopped working. I pulled off the belt and it was completely chewed up. I replaced the belt, and it is still screaming like a banshee.
-The noise seems to come and go intermittently.
-I've experimented with belt tension, but that seems to make no difference.
-The harmonic balancer was recently replaced.
I would lean toward thinking this might be a bad alternator bearing, but if that was the case, would the noise come and go (usually several times in one trip)?
.. Good thing it didn't shave the wires too bad
. I don't know if you fixed it but check all the surrounding wires, if anything is rubbing against or looks ground down from the belt rubbing.
