86MCSS
- 244
- Jun 18, 2003
Im just going to give you the entire story so there is no details left out.
--I bought a talon with a trashed engine and it took me about 3 weeks to fix it. The day I go to start it, it will not start. It had no engine codes and cranked over fine and It had good spark and fuel and compression. I sparyed starting fluid into the engine and it started. I let the engine sit there and idle and burn off its initial start up smoke and it threw a code for the coolant temp sensor. I check the plug and its trash so I fixed it and the code went away. And also the engine is idling at about 3k rpm. I adjusted the CAS and BISS screw and it only went down to 2k. It was getting late so i left the car alone until I had more time.
--NOW Its the middle of the week and I get home early from work and decide to mess with the talon. I crank and crank the car and it will not start. Sparyed starting fluid again and it starts again and revved to 2k rpm and stood there again, I checked the logger and it said I had 35 degrees of timing[no knock] at idle! I messed with BISS and throttle body cable and could not get it any lower. Checked the timing marks again and again as well. I messed with everything for a couple hours and it got dark so I left it alone again.
--Now this weeked I go to start the car again and it will crank and crank and not start. I spary starting fluid in it and it still will not start this time. I check my logger and its throwing code 41 [injector circut]. I checked the injectors and they all have 2.8 ohms. My manuel says it should be between 2 and 3. While i was down there i checked the ISC motor as well and it had 28 ohms so that checked out fine as well. I have checked all my fuses and spark and compression and fuel and its all there. It just will not start.
1.What else can I check that would throw code 41 [injector circut]? The injectors are squirting fuel.
2.Why is my idle so high? I checked the timing marks many times and they are all fine. I have no vacuum leaks and have not checked for boost leaks cause the car has not seen any boost as of yet.
All help is appreciated. If anymore info is needed please ask.
