sedah
- 59
- Mar 26, 2004
vancouver,
Washington
start the car... if i could record it i'd do it right away because its not a good sound...
about 3-5 seconds of this strange metal on metal spinning but not sound I Will record this at the first possible chance... its sickening sounding for me to hear
started after i had a battery (never by exide.) only top charge
i made the mistake of holding the key while the battery charged up somewhat and eventually (perhaps a good minute or so later) start up
i did this for about a week twice a day to and from work
afterwards i had my clutch done
bought a redtop optima battery (why not?)
just prior i had a mechanic perform my 60k services
i've changed my 1gen exhaust manifold to a 2g unported (had some major cracking)
had a broken throttle body gasket .. fixed with rtv silicone *chuckles* ghetto
ALright thats just ONE problem to diagnoise today...
SEcond While running particularly at idle there is a singular strong tapping knock that increases with rpms until the engine becomes louder then the knocking sound. yet my datalogger detects no knock from the knock sensor which baffles me because this is not some quiet tap (not the ticking from lifters)
Third
between 2-3k rpms roughly and ONLY at decelleration i get this Loud gurgling bubbling exhaust sound and its damn loud
on second thought it may not be exhaust
if your transfer case is going out what are the symptoms?
in all extreme cases and subtilities
engine mounts are 14 years old so at decel it would rest differently then with any throttle pressed making it tilt silghtly differently perhaps causing noise? i'm not sure to tell the truth
all i know is it sounds like exuast really loud exhaust
And lastely for now
its getting cold out
i'm scared my lil 14b is going out cold makes ya see the early exhausts more
well
after warming it up a lil while somewhere round 100 coolant temp
i take off down the road
and its only when its cold so far sa i've seen and its cold out side
when i hit turbo it leaves this lingering pot hole of nasty white smoke in the middle of the road
its very white not blueish at all to me
perhaps greyish though
i've only seen it in the rear view mirrors and faintly when i turned around once
but i dont leave a trail of nasty smoke behind me as i go down the road least not one i can see
args
any help would be greatly appreciated
anyone living in the vancouver area of washington state know if dick hannah is the only chrysler dealer within reasonable distance? (had a bad experience with them would much perfer somewhere else) i need the t case recall performed .. built in november of 90 .. this 91's gone this long without the recall performed and only has 57k on the meter
whats a clogged cat sound like?
Third
And lastely for now
well
args
