Keep getting boost leaks
HooverCJL24
136
Mar 30, 2004
North Canton, Ohio
I searched for this and couldnt find an answer...but anways, on my way to colombus the other day i pushed the gas and heard just air and the car shook. Got there, found out it was a t clamp by the mbcand some how it got a hole blown in it. Replaced it. All is well again. Then 2 days ago. another leak happened when i accelerated hard. This time it was the tube coming from the intake manifold going to the MBC. Fixed that. All is well again. Then tonight on the way home from work something else blew, i looked at those 2 spots and looked at all the other hoses i could see, didnt see anything bad. Im ognna run a boost leak test once i get the device made. Iv had my car for 6 months and have never had any boost leak problems and all the sudden i have had 3 in hte past week. Is something causing this or is it just luck. Is there any way i can find my latest leak without the tester because i dont have an air compresser. Any feedback helps. Thanks
spray soapy water around suspected areas, or make the tester, go to wal-mart and get a $10 bike pump or a air bottle and fill it up at a gas station, or just do your test a gas station
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
