josherino
- 148
- Sep 18, 2004
Ft Collins,
Colorado
hey I have white smoke coming out of the exhaust. I had a compression check 600 miles ago and it was fine. Also moisture is right inside the muffler, and cupping my hand aroud the exhaust flow I get a slight moisture on my hand. There is not a lot of white smoke and the coolant level has not gone down. I have done research and I believe that it is my head gasket, but I want to make sure. the smoke gives off a gasoline smell. plus, how bad is it to drive on a bad head gasket? What is a good aftermarket head gasket?
