Clutch problem
bisne
Sep 22, 2004
Calexico, California
Hi, this its the problem , its a 96 tsi talon, the clutch its acting weird, the pedal its fine, and the master and the slave cylinder dont leak, but some times its dificult to shift in all gears, I need to pump several times to get in gear. But the really strange its when I put in reverse and start disengage the clutch the car or the engine shakes hard. :confused:
Any advice are welcome.
Thanks for the reply, I check out the car a notice that the rear engine motor mount bracket was missing WEIRD, but I Installed one, and now when I try to disengage the clutch in 1RSt gear the car shakes hard, ILL try to adjust the linkage tomorrow and bleed the clutch fluid.
Thanks.
