boostmaster123
- 92
- Nov 16, 2002
Chicago,
Illinois
Like the title states, i just hooked up some indiglo gauge faces to my dimmer switch and now my defi Bf's only light upwhen i have the headlights on. The gauges work and everything because i can see the needle moving but they arent lit up. My defi's are hooked into a fuse and like is said the gauges are hooked to the green/white line from the dimmer. what is causing the problem with my gauges now? also why is it that when i turn on my headlights i get a flicker from the gauges and then they turn on? is there a relation between the two? any comments are much appreciated.
