DiamondStarCar
- 60
- 2
- May 7, 2004
Mansfield,
Texas
Ok I have only had my 1g awd for about a week now, and I was wondering if I have a problem with my t case or something. I got the awd because I heard about how you can launce these things at 5,000rpms and they just shoot forward. Well, I've been kind of carefull by only launching my car at 3 or 4,000rpms. When I drop the clutch, there is some bogging and a clunk coming from the front of the car. I think I may be dropping the clutch to fast and need to be more steady...but I should be able to launch these things pretty hard right? Please tell me if this "clunk" is just me letting off the clutch too fast or if it's a real problem I need to worry about.
Also, the car's clutch has 35k miles if that helps...it's not slipping. When I am already accelerating from a roll, it grips great and takes off fast. However, I sold my Fwd and got this Awd because I like the faster launch. Please help.
basically the inside of the rubber gets worn away...jack your car up and grab the driveshatf and move it....if it moves too much, that is probably your problem....being a quick fix, i would try it and it only and see if it fixes your problem...if it doesnt, then look into the u joints
