please help me
NevaSatified
Feb 17, 2004
New Orleans, Louisiana
my 1g is idling rough as hell. The turbo wont boost, it gets to '0', but will not boost at all. What would this problem be? turbo fuked, or is it some kind of sensor holding back boost? sorry im a newb to DSMs
Goto Vfaq.com make a boost leak tester and check it out. You have a leak somewhere if you can't make boost unless your turbo bit the big one.
ok thanks, ill do that. Someone suggested my wastegate may be stuck on full open or osmething, not allowing the turbo to compress. The rod coming off of hte turbo to the wastegate is stuck, and doesnt move whatsoever. Im going to put the car on a scanner wednesday and pull ECU codes, and going to check for leaks i suppose. Any other suggestions are helpful. Oh, and the car idles and drives fine now, just NO boost
