Oil Leak
BigLGST
272
Sep 17, 2003
Chicago, Illinois
I have an oil leak by the crank pulley, looks like to be in between the crank pulley and the block. I did replace the crank pulley about 6 months ago, but is there a sealant that goes in between them? This oil leak sometimes is a drop every couple minutes but yesterday it leaked about half a quart constant, then when I start drivin it stops. Is it safe to drive the car like this? And any suggestions on how to stop the leak would be greatly appreciated. Thanks
Any oil leak with a turbo car is bad stuff, especially if your leaking as much as you say. I hear they sale this stuff you can put in the oil that changes the color of your oil to help you find leaks, if you wanta try to find and fix yourself. Otherwise I would take it to a shop and have them find it. But def get that fixed sooon.
