crashed97tsi
- 828
- Apr 21, 2002
Bethlehem,
Pennsylvania
Ok, I have had a really bad cooling problem as of late and I need a few ideas. Any help would be appreciated.
What's already been done.
1. Thermostat replacement.
2. Coolant flushed twice with zerex superflush (the one you have to drive around 6 hours with). New coolant, redline water wetter, and corrosion prevention/ water pump lubricant added.
3. Radiator cap replaced.
4 Compression checked, 180,178,180,178
The only thing odd I noticed the whole time was that refilling the coolant last time, it only took 1 gal of antifreeze, the water wetter and the lubricant, after that it was full. So I figured I try to burp it, it overflowed and took no additional water. It was bubbling alot tho. My question is is it possible to blow a headgasket when you don't lose any coolant, burn any coolant, nothing is mixed, and your compression checks out fine? Or do I need to just add more water to the mix? The water pump is also working fine.
