too much spark???
streetraceboi
Moderator
828
369
Sep 4, 2002
San Antonio, Texas
ok, ive blown cracked/blown 3 pistons already in the #1 cylinder. i cant seem to figure out why though. a friend of mine told me that im running lean, but why in that one cylinder only??? if i was running lean, wouldnt it be blowing all pistons?? im tired of this happening and i want to fix it to avoid blowing another piston.... i have noticed when i was checking the spark that when i would pull out the wires when the car was on that the 2,3,and 4 cylinders were throwing normal spark, but when i would pull out the #1 wire, it would be throwing a strong spark. this had never happened until i replaced the ignitor with another used one when mine went out. could this be the prob?? i need help bad, any info will be appreciated, thnx. and also i have no major mods, just basics as in catback, and mbc set at 12psi.
If one injector is not operating correctly, it can cause you to run lean in an individual cylinder.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
