ThUnDaKaT85
- 82
- Feb 5, 2004
Houston,
Texas
ok, so i get the 9 nuts off the studs that connect the manifold to the block, then i get off the 3 bolts, and the nut that connect manifold to turbo, but i cant get the stud out. and i cant pull the manifold either way to get it away from the studs. is there any way of not having to take apart the turbo and everything? i tried vfaq, but it didnt help much. i just need a simple instruction on what i should do
