Help sqeaky start up
mollinco
Jul 23, 2002
My car sqeaks when i start it up and it gets louder when i push on the gas and i can not pin point the issue i just replaces the timming belt and the drive shaft pully and after that is when it started my friend had this issue and they replayed either the a/c pully or pully belt. do you have any ideas you can also email me at [email protected]
Mine does it to? I did the same replacements as you. It was REALLY bad then I went and tightend the alt. belt. Now it does it (quietly) for a sec then stops?
696
Definitely one of the accesory belts. There is a tensioner for both. If you check, there is one on the alternator, just make it tighter, and if not, there is another one, behind the timing belt near the A/C pully. If the belts are good, just tighten them.
