69_luv
- 522
- 9
- Nov 3, 2003
Jacksonville,
Florida
This is at almost all temps, except for when the car is warm. Its really really hard to start. If you just hold the starter over and try to start it that way it won't start. If you bump it a couple turns, pump the gas, bump it a couple turns, give it some gas, eventually it starts.
I had a problem with my first walbro 255, so I installed another one. When you turn the ignition on, before you bump the starter should you hear the fuel pump whining?
I know it can be only two things, fuel or spark. I put new NGK wires, and plugs in, gapped the plugs to .028.
Once the car starts idle kicks up and the car runs great...
The longer the car sits the harder it is to start.
Thanks for any help guys
