SpoolinGSX
- 84
- 1
- Nov 4, 2002
Bay Area,
California
The car has been driving fine for the a while now with no problems it seems. I turned the car off yesterday and the turbo timer worked as it usually does. I went back out last night to turn the car on and went I put the key in everything was fine, turned to to the acc position, fine, but when I turned it to the on position all the lights on my dash just went out as well as all of my gauges. No starter solenoid click, no start. When I took the key out and tried it again the lights never came back on. Went out today to try again, same thing. Lights were on when I got there and once I got it into the on position everything turned off.
I check the battery voltage and that is fine, and the car has been running with normal voltage on the voltmeter. I am not a guru on electronics systems. Any ideas of what it could be or were to start checking with the multimeter?
it could be your ignition switch!
