Ghost1984
- 1,235
- 3
- Dec 29, 2003
Southwest,
Missouri
I still seem to have a misfire. It happens when the car idles, and when im driving at partial throttle. i have a 94 eclipse 2.0, ive put in bp6res plugs, gapped at 0.40, put in new wires all correctly, and it still seems to misfire, i cant figure out why. Is there anything else i need to check, im not sure if it would be the coil because that either works, or it doesnt. Am i running the right heat range on plugs, i usually run the bp7res, but im mildly modified(intake, header, exhaust etc....) which plug would be better, and what else could cause this problem, if anyone could give me some ideas it would be greatly appreciated, its been doin this for about about 3 weeks and its very annoying and I need help with it. Thanks.
