SilverEclipseT
- 209
- Mar 7, 2003
Allentown,
Pennsylvania
I'm running 8psi of boost on my eclipse and im having problems getting the FP to rise enough or at all to support the boost. I currently have a Vortech SFMU and walbro 255lph with stock injectors.
I have tried putting a pump on the regulator and setting it at 8psi so the FP will rise to about 100psi and stay there ok...good the regulator works. So i start to drive and as soon as the turbo spools past 3psi the FP drops down like a bullet to 20psi (no change to the regulator). I tried clamping the return line by the tank and it took forever for the FP to start to rise. Next i tried to clamp it before the regulator the FP rose quicker but i dont think quick enough.
So according to the graph that i attached i may have gotten the wrong Fuel pump. I bought this pump off ebay new and it was listed the same as all the rest - walbro 255lph, but im thinking i should have looked for the walbro 255lph-HP.
Can anyone verify having this problem with this pump or tell me if this graph is accurate. I have been trouble shooting this for like 2 weeks
and this is about all i can come up with.
The next thing i was going to try is making a direct power line from the battery to the pump, but i dont think this will change anything.
and this is about all i can come up with. The next thing i was going to try is making a direct power line from the battery to the pump, but i dont think this will change anything.
