excessive inside tear wear, even though #'s are in spec?
mach1one
232
Nov 30, 2003
A B., Alabama
I replaced a couple belts this weekend, and I noticed that the inside of my front 2 tires were a good bit more worn that the outside. The rears looked somewhat fine. I had new kumho 712s + alignment done at the same time about 2k miles ago. Here's the specs.
Front
Left
Camber -.1
Caster 2.2
Toe -.04
Right
Camber -.1
Caster 1.9
Toe -.04
The rear specs
Left
Camber -.1
Toe .07
Right
Camber -.5
Toe .09
I have a lifetime alignment deal, should I take it in and get the toe adjusted closer to 0? The sheet they gave me shows the front toe range being from -.06-.06. The tires aren't close to shredding or anything, it's just the insides are a bit more worn than the outsides.
yes take it back and get the toe to 0 if ur anal about tire wear.
what suspension set up do you have? do u have any worn bushings that could lead to this?
I have the same problem. I got the same tires too. Even with good alignment, the tires wear out more on the inside. I figure my reasons
1.) active toe in
2.) driving too hard specially around turns. (I like it when my tires squeal) :D
3.) wheel bearings
I had both my rear toes set 0 if I remember right
Reason I'm post is bc I live near yo2001 and he mentioned he had excessive wear even though his were in spec. I checked and I did too.
I guess I'll double-check my air pressure and rotate those tires to the back and watch it more closely. If it keeps it up then I'll get the toe adjusted back to 0.
I have nothing as far as susp. goes. I haven't checked the bushing or anything.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
