Sotarts
- 1,953
- 21
- Sep 30, 2002
Chicago,
Illinois
Every time I shift into second gear, the lever feels as if it's not engaging fully, feels as if it's not securely in there (I must make sure I take some more time doing it), although it doesn't pop out. This is my #1 problem, a very big nuisance.
If I launch the car and quickly shift to second, it won't go in most of the time (and of course it would grind), unless I take my time to make sure it feels like it's fully engaged (as far as the lever can go, with a "click" feel).
Reverse gear popped out on me few times--I think I've shifted to reverse and let off the clutch very quickly those times.
Sometimes when I sit at idle, feels and sounds as if something is rattling while spining. It goes away once I rev up, sometimes the noise/vibration comes back when RPMs fall back to idle or little above idle while falling to idle level.
Few times when I shifted to 1st while sitting at idle, felt like something engaged in the transmission (almost sort of like placing automatic transmission from neutral/park into drive type of feeling, although that doesn't create any movement of the car). This happened enough times for me to notice. Happens VERY rarely, I don't even remember the last time that happened.
A lot of times I have a problem shifting into 1st while standing still at idle. Half-way through the shift motion something is not letting it. Not all the time though.
Can someone explain to me what each problem is associated with and what specifically would eliminate each problem? (Without plainly telling me that I need a new/rebuilt transmission)
Shifting throughout all gears feels a little heavy. I do fully engage the clutch pedal.
Using Mobil 1 fully synthetic manual trans fuild, very recently changed.
'90 AWD. Clutch Masters #2500 clutch. Transmission supposedly rebuilt few thousand miles.
Thanks.
Thanks.
