TooMuchStereo
- Mar 30, 2004
New Orleans,
Louisiana
Ok, So I did a little searching, and I just want to make sure of something before I go and do it...
The Cam Angle Sensor, does it need to be adjusted, if I'm taking the sensor off of one engine, and installing it on a different engine?
Does it matter?
I ask because I just recently finished putting my Talon back together with a replacement engine, and just finished putting the engine bay back together, but when I go to crank it, the engine turns over, and coughs and jerks like it's about to start, but it doesn't actually fire
I have fuel and air (already checked and double checked), and the timing should be correct; all the timing marks are lined up correctly when #1 is at TDC. The ECU should be fine, it was working fine before the engine swap, and it never made any funny smells (I previously owned a Mitsu Mirage, and I know what the burned out ECU looks and smells like)
Thanks, Jake
Does it matter?
Thanks, Jake
